HTTP Rest api call maximum results
Alejandro Madurga Ainoza
Hi all,
I´m trying to get data from the portal using the follwoing rest api call:
http://<ServerURL>/RequestCenter/nsapi/serviceitems/serviceitemsubscription
but it only gives me 20 results, which I believe it is the default, is there any way to get all the elements or a way to page all the results?
Alex.
Hi all,
found some info on the Integration guide (Cisco Prime Service Catalog 10.0 Integration Guide) page 222, there is a section regarding Paging, but the max results are 50.
I was looking a simple way to export / import info from the portal, but it seems Java is going to be neded instead http nsapi.
Alex.
