IAC, Adding Network bigger than /24
laurentmonnard
We are interested on setting on the portal subnets bigger than /24.
It appears that this is not in the Portal default setting.
This is something we really need to do and we are wondering if anyone had already done or tested this change?
If yes, could you please tell us how did you do this and if you encountered any unexpected behavior once this done? Is there any limitations once this changed?
If not, are you aware of any risks by doing it? Is there any warning we shall be made aware of?
Many thanks in advance for your help and answers.
Lee Calcote
Level 3
Level 3
IAC 3.1 (and IAC 3.1.1) support subnets ranging from /23 to /29.
