Insert JobGroup through REST API failing with null pointer exception
PeteCr
We are inserting job groups into the schedule using the REST API.  In our DEV environment all goes well.  In higher regions we are getting a null pointer exception thrown at:
 com.tidalsoft.webclient.tes.dsp.api.JobHandler.insert [JobHandler.java 93]
No idea how to debug this.  The POST data is the same for both regions:
<?xml version='1.0' encoding='UTF-8'?><entry xmlns="http://purl.org/atom/ns#">
  <tes:JobGroup.insert xmlns:tes="http://www.tidalsoftware.com/client/tesservlet">
    <tes:id>12345</tes:id>
    <tes:startdate>20180501</tes:startdate>
    <tes:fromtime></tes:fromtime>
    <tes:untiltime></tes:untiltime>
    <tes:params>dfd2db33e6b6</tes:params>
    <tes:vars></tes:vars>
    <tes:deps>N</tes:deps>
    <tes:usejobtz></tes:usejobtz>
  </tes:JobGroup.insert>
</entry>
0 Replies 0
