java.net.SocketException: Protocol family unavailable
Hi All,
Being a new member of Cisco Service Community, I would like to say "Hello" to everyone and also pardon me if I am missing any information here. I am really looking for your expertise here :)
Two VM topology architecture of my environment:
Application servers with CPSC11.1: RHEL7.2
Production 1 (Cluster Node1): Domain Controller --> Service Link + RequestCenter
Production 2 (Cluster Node2): Host Controller -> RequestCenter.war
Both Production 1 and Production 2 are using IPv4 and not IPv6.
I have installed CPSC 11.1.1 which is bundled with Wildfly 8 on Red Hat Enterprise Linux Server release 7.2 (Maipo) as cluster install (choose complete cluster option during install) only on my cluster node1 (nothing installed in production 2 box as of now ). After successful install, I tried to start CPSC service with following command:
nohup ./startServiceCatalogCluster.sh > startServiceCatalogCluster.log 2>&1 &
However, I am getting error: "Protocol family unavailable"
Here is the complete log file:
nohup: ignoring input
Starting serviceCatalog in Cluster.....
JBoss Bootstrap Environment
JBOSS_HOME: /opt/app/workload/CiscoPrimeServiceCatalog/wildfly-8.2.0.Final
JAVA: /opt/app/workload/jdk1.7.0_99/bin/java
JAVA_OPTS: -server -Xms4096m -Xmx4096m -XX:PermSize=512m -XX:MaxPermSize=512m -XX:NewRatio=2 -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=/log -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.base.dir= -Djboss.domain.config.dir=/configuration -XX:CompileCommand=exclude,com/newscale/bfw/signon/filters/AuthenticationFilter,doFilter -XX:CompileCommand=exclude,org/apache/xml/dtm/ref/sax2dtm/SAX2DTM,startElement -XX:CompileCommand=exclude,org/exolab/castor/xml/Marshaller,marshal -XX:CompileCommand=exclude,org/apache/xpath/compiler/XPathParser,UnionExpr -XX:CompileCommand=exclude,org/apache/oro/text/regex/Perl5Compiler,__parseAtom% -Dnewscale.logger.dir=/opt/app/workload/CiscoPrimeServiceCatalog/wildfly-8.2.0.Final/domain/servers/server-hostva-SL/log
14:54:50,045 INFO [org.jboss.modules] JBoss Modules version 1.3.3.Final
14:54:50,328 INFO [org.jboss.as.process.Host Controller.status] JBAS012017: Starting process 'Host Controller'
[Host Controller] 14:54:51,548 INFO [org.jboss.modules] JBoss Modules version 1.3.3.Final
[Host Controller] 14:54:51,831 INFO [org.jboss.msc] JBoss MSC version 1.2.2.Final
[Host Controller] 14:54:51,945 INFO [org.jboss.as] JBAS015899: WildFly 8.2.0.Final "Tweek" starting
[Host Controller] 14:54:53,652 INFO [org.xnio] XNIO version 3.3.0.Final
[Host Controller] 14:54:53,652 INFO [org.jboss.as] JBAS010902: Creating http management service using network interface (management) port (9990) securePort (-1)
[Host Controller] 14:54:53,684 INFO [org.xnio.nio] XNIO NIO Implementation Version 3.3.0.Final
[Host Controller] 14:54:53,794 INFO [org.jboss.remoting] JBoss Remoting version 4.0.7.Final
[Host Controller] 14:54:53,851 ERROR [org.jboss.msc.service.fail] MSC000001: Failed to start service jboss.remoting.server.management: org.jboss.msc.service.StartException in service jboss.remoting.server.management: JBAS017113: Failed to start service
[Host Controller] at org.jboss.as.remoting.AbstractStreamServerService.start(AbstractStreamServerService.java:112) [wildfly-remoting-8.2.0.Final.jar:8.2.0.Final]
[Host Controller] at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1948) [jboss-msc-1.2.2.Final.jar:1.2.2.Final]
[Host Controller] at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1881) [jboss-msc-1.2.2.Final.jar:1.2.2.Final]
[Host Controller] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [rt.jar:1.7.0_99]
[Host Controller] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [rt.jar:1.7.0_99]
[Host Controller] at java.lang.Thread.run(Thread.java:745) [rt.jar:1.7.0_99]
[Host Controller] Caused by: java.net.SocketException: Protocol family unavailable
[Host Controller] at sun.nio.ch.Net.bind0(Native Method) [rt.jar:1.7.0_99]
[Host Controller] at sun.nio.ch.Net.bind(Net.java:463) [rt.jar:1.7.0_99]
[Host Controller] at sun.nio.ch.Net.bind(Net.java:455) [rt.jar:1.7.0_99]
[Host Controller] at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) [rt.jar:1.7.0_99]
[Host Controller] at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74) [rt.jar:1.7.0_99]
[Host Controller] at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:67) [rt.jar:1.7.0_99]
[Host Controller] at org.xnio.nio.NioXnioWorker.createTcpConnectionServer(NioXnioWorker.java:182)
[Host Controller] at org.xnio.XnioWorker.createStreamConnectionServer(XnioWorker.java:243) [xnio-api-3.3.0.Final.jar:3.3.0.Final]
[Host Controller] at org.xnio.XnioWorker.createStreamServer(XnioWorker.java:145) [xnio-api-3.3.0.Final.jar:3.3.0.Final]
[Host Controller] at org.jboss.remoting3.remote.RemoteConnectionProvider$ProviderInterface.createServer(RemoteConnectionProvider.java:309) [jboss-remoting-4.0.7.Final.jar:4.0.7.Final]
[Host Controller] at org.jboss.as.remoting.AbstractStreamServerService.start(AbstractStreamServerService.java:102) [wildfly-remoting-8.2.0.Final.jar:8.2.0.Final]
[Host Controller] ... 5 more
[Host Controller]
[Host Controller] 14:54:53,868 ERROR [org.jboss.as.controller.management-operation] JBAS014613: Operation ("add") failed - address: ([
[Host Controller] ("host" => "HOST1"),
[Host Controller] ("core-service" => "management"),
[Host Controller] ("management-interface" => "native-interface")
[Host Controller] ]) - failure description: {"JBAS014671: Failed services" => {"jboss.remoting.server.management" => "org.jboss.msc.service.StartException in service jboss.remoting.server.management: JBAS017113: Failed to start service
[Host Controller] Caused by: java.net.SocketException: Protocol family unavailable"}}
[Host Controller] 14:54:53,916 INFO [org.jboss.as.controller] JBAS014774: Service status report
[Host Controller] JBAS014775: New missing/unsatisfied dependencies:
[Host Controller] service jboss.remoting.endpoint.management (missing) dependents: [service jboss.jmx.remoting-connector-ref, service jboss.remoting.management.channel.registry]
[Host Controller] JBAS014777: Services which failed to start: service jboss.remoting.server.management
[Host Controller]
[Host Controller] 14:54:53,920 FATAL [org.jboss.as.host.controller] JBAS010933: Host Controller boot has failed in an unrecoverable manner; exiting. See previous messages for details.
[Host Controller] 14:54:53,989 INFO [org.jboss.as] JBAS015950: WildFly 8.2.0.Final "Tweek" stopped in 9ms
14:54:54,352 INFO [org.jboss.as.process.Host Controller.status] JBAS012010: Process 'Host Controller' finished with an exit status of 99
14:54:54,356 INFO [org.jboss.as.process] JBAS012016: Shutting down process controller
14:54:54,357 INFO [org.jboss.as.process] JBAS012015: All processes finished; exiting
I figured it out
Updated host.xml (/opt/app/workload/CiscoPrimeServiceCatalog/wildfly-8.2.0.Final/domain/configuration/host.xml)
and hostva_backup.xml (/opt/app/workload/CiscoPrimeServiceCatalog/wildfly-8.2.0.Final/domain/configuration/hostva_backup.xml)
to this and Issue Resolved
<interface name="management">
<any-ipv4-address/>
</interface>
<interface name="public">
<any-ipv4-address/>
</interface>
<interface name="unsecure">
