JDEdwards Launch failure - JdeNetTimeoutException
john.haberland
Has anyone else running JDEdwards encountered the following error periodically and if so what was the cause?
Launch failure: JDE request failed: com.jdedwards.system.net.JdeNetTimeoutException
adilliba
Hi John,
Can you check that the following parameters are updated in enterprise server jde.ini file
Review the following and make changes as appropriate:
LINUX/SOLARIS/AIX/HPUX
[JDENET_KERNEL_DEF16]
krnlName=XML LIST KERNEL
dispatchDLLName=libxmllist.so (.sl for HPUX)
dispatchDLLFunction=XMLListDispatch
maxNumberOfProcesses=1
numberOfAutoStartProcesses=0
[JDENET_KERNEL_DEF22]
krnlName=XML DISPATCH KERNEL
dispatchDLLName=libxmldispatch.so (.sl for HPUX)
dispatchDLLFunction=JDEK_XMLDispatch
maxNumberOfProcesses=6
numberOfAutoStartProcesses=1
WINDOWS
krnlName=XML List Kernel
dispatchDLLName=xmllist.dll
dispatchDLLFunction=_XMLListDispatch@28
dispatchDLLName=xmldispatch.dll
dispatchDLLFunction=_XMLDispatch@28
AS400
dispatchDLLName=XMLLIST
maxNumberOfProcesses=3
beginningMsgTypeRange=5257
endingMsgTypeRange=5512
newProcessThresholdRequest=0
dispatchDLLName=XMLDSPATCH
dispatchDLLFunction=XMLDispatch
 [XMLLookupInfo]
XMLRequestType1=list
XMLKernelMessageRange1=5257
XMLKernelHostName1=local
XMLKernelPort1=0
XMLRequestType2=callmethod
XMLKernelMessageRange2=920
XMLKernelHostName2=local
XMLKernelPort2=0
XMLRequestType7=ube
XMLKernelMessageRange7=380
XMLKernelHostName7=local
XMLKernelPort7=0
XMLKernelReply7=1
Once you are done, restart the enterprise server and try scheduling jobs
Ashwin
