LDAP authetication in Tidal 6.3.1
Viji
Users logging with LDAp authetication in Tidal 6.3.1, is their passwords encrypted? Thanks.
balaji.bandi
it is depends on how you have setup the network. is the user using SSL/TLS, Tidal configure LDAP(s) query users  information ?
As long as end to end configured secured in the network - best effort it is secured.
It again all depends on how you design and configure.
BB
Thanks for your reply. We are using HTTPS with TL1.2 protocol. Recentlu with security audit they are saying our password were unencryted using LDAP authetication. Just would liketo know if there is any configuration needs to be done in Tidal, Thanks.
