Mainframe Integration
Patti Richards
Has anyone ever integrated with the mainframe to issue RACF commands to query users, create users, delete users, etc?
I'm interested in your chosen approach- Were you able to use any out of the box adapters or did you have to write a custom adapter.
Is there anyone out there that has written a custom adapter?
Trying to evaluate our options.
Patti Richards
Has anyone used the MQ Adapter in prod?
Emir AmEx (9.1)
yes, with extended poller customization
Patti Richards
Was the customization on the mainframe side or the newscale side?
Emir AmEx (9.1)
let me rephrase this:
We are using a customized MQ poller adapter on the newScale side, which drops off a message into a clustered MQ queue
