MCAK for vCloud Director 5.1
Paul Jeffrey
We have been using the latest MultiCloud for vCloud Director but are now looking at upgrading to vCenter and vCloud Director 5.1.
I had seen some mention of support coming soon for the version 5.1 of vCD, but have not seen if it is available or in what version it will be.
Would you be able to give some indication on the support for this version please?
Paul
derevan
Level 4
Level 4
You should have no issues using the latest version of MCAK with vCloud Director 5.1. All IAC functionality has been verified. What is not supported yet is the VCD 5.1 API, so you would not be able to take advantage of new API/product features with the PO VCD adapter (although, you could always write your own custom process using HTTP requests to call the new REST API directly).
derevan
Level 4
Level 4
Hi Derek
Thanks for your fast response.
At the moment all we are wanting is the same IAC functionality in vCloud Director 5.1 as we are just upgrading the underlying infrastructure and none of the new features are needed, so this will be perfect for us then.
Paul
