nS 9 and Text Display Properties (AFC)
Text Display Properties not working in newScale 9
Has anyone tested the newScale 9 in dev yet? We have an issue where the display properties of a text field is not taking effect when configuring the column length. It will just remain the default length no matter what the value is set at. We have exported the service from nS 9 back to 2008.3 and the text display changes work as expected. Is there a work around for this or is this a known bug?
Hi Craig,
Good news -- there is a hotfix for this already available. If you are going to be installing SP1 for newScale 9, the hotfix is included in the service pack. If you are not planning to install SP1, please contact customer care and ask them for 2009.1_HotFix_FormDataTypeTransform.
