Outbound Transport Failed while initializing Licenses
msabuwala
Hi there,
I am stuck at the configuration wizard while initializing licenses, the nsAPI user is a domain user and Basic authentication has been set for Web Services as well as while configuring the outbound agent.
Now since the nsAPI user is a domain user, does LDAP integration needs to be enabled, if yes, can someone please provide me the exact mapping details as the ones mentioned in the document doesnt work.
I am also struggling to get the Mappings tested, the integration guide as well as the configuration guide is a little confusing, can someone please help.
I have attached the message routing exception error details.
Mohammed
0 Replies 0
