Passing Cookies from Previous Web HTTP Request to the Next
mcofino
I have two Web Http Requests. The first one performs a Login and the second one executes another method called ListRecoveryPlans.
First SOAP calls for Login looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap-url>https://srm-app-003:9007</soap-url>
<connection>
<name>srm_connection_test_01</name>
<terminate-on-exit>false</terminate-on-exit>
</connection>
<SOAP-ENV:Body>
<urn:SrmLogin xmlns:urn="urn:srm0">
<urn:_this xmlns:urn="urn" type="SrmApi">Srm</urn:_this>
<urn:username>cisco\xxx</urn:username>
<urn:password>xxx</urn:password>
</urn:SrmLogin>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
The second soap looks like this:
<connection>
</connection>
<connectionCookie>
<name>
<xsl:text disable-output-escaping="no">DE78D964-DDF4-40B6-BCB7-BEB44624826D</xsl:text>
</name>
</connectionCookie>
<SOAP-ENV:Body>
<urn:ListRecoveryPlans xmlns:urn="urn:srm0">
<xsl:text disable-output-escaping="no">Srm</xsl:text>
</urn:_this>
</urn:ListRecoveryPlans>
</SOAP-ENV:Body>
In addition, under the Cookies tab for the ListRecoveryPlans request, I passed the cookies from the previous request:
However, I am getting a "session is not authenticated" error.
The remote server returned an error: (500) Internal Server Error.
<soapenv:Envelope xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<soapenv:Fault><faultcode>ServerFaultCode</faultcode><faultstring>The session is not authenticated.</faultstring><detail><SecurityErrorFault xmlns="urn:srm0" xsi:type="SecurityError"></SecurityErrorFault></detail></soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
Can you shed some light on how I can fix this issue? I am using CPO v. 2.2.0.1409.
Thank you.
Mary Jane Cofino
Shaun Roberts
On the first request, did you check to accept cookies from it? Can you try viewing the cookie table and making sure you are getting it in the first call?
If you need more help, open a TAC case.
-shaun
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Thank you for the prompt reply.
For the first request, here is the response header I am getting
I checked the "Accept cookies from this request" checkbox button and am now getting a new error:
ServerFaultCodeThe object has already been deleted or has not been completely created
Mary Jane Cofino
A 500 error means an error on the application you are calling.
Have you tested this with like SOAP UI or some other manual soap engine?
-shaun
--Shaun Roberts
shaurobe@cisco.com
