Ports in use with Tidal
Michelle Morris
Hi All - I am needing a list of all ports that Tidal uses.  I have seen this kind of list before, but I can't find it.
I'm especially interested in whether a port in use is bi-directional or if two Tidal components have one way ports.
Does anyone have a list like this?
Thanks!
Michelle
Derrick Au
Level 4
Level 4
Hi Michelle,
You can find Tidal port information within the Reference Guide, Chapter 2: Getting Started \ Connections Pane.
BR,
Derrick Au
Thank you Derrick
Here is what I have found:
From the Reference Guide, Chapter 2: Getting Started\Connections pane
  • Master to Agent port: 5912
  • Agent to Master: 5591
  • Backup Master to Master: 6704
  • Fault Monitor to Master (Backup Master): 6703
  • Fault Monitor Client Port: CM to FM: 6705
Not listed in the Reference Guide:
  • Master to CM/CM to Master (also Backup Master): 6215
Hope this helps someone else!
Michelle
