Possible to change the display order of dictionaries dynamically?
lim.park01
Is it possible to change the display order of dictionaries dynamically?
Have a need to reorder the dictionaries depending on which task the form opens in... if anyone can share anything similiar they have done.
Thanks.
derevan
Level 4
Level 4
If you have Multi-Cloud installed, you can see an example of this in the MultiCloud_Platform_Handler JavaScript (triggered during form load) where the Multi-Cloud dictionary is moved to the top of the form:
if   (ServiceName == 'Add Network')  {
    // Re-order the dictionaries on the form
    var MultiCloudNetwork_Element = document.getElementById("MultiCloudNetwork.DictionaryTable");
    var VLANInstance_Element = document.getElementById("VLANInstance.DictionaryTable");
    var VLANCustomerInput_Element = document.getElementById("VLANCustomerInput.DictionaryTable");
    VLANInstance_Element.parentNode.insertBefore(MultiCloudNetwork_Element  , VLANInstance_Element );
    VLANInstance_Element.parentNode.replaceChild(VLANCustomerInput_Element  , MultiCloudNetwork_Element  );
    VLANInstance_Element.parentNode.insertBefore(MultiCloudNetwork_Element  , VLANCustomerInput_Element );
You should be able to follow this example.
Thanks Derek. I will test it out but sounds like that should work.
