problem with spool file for job in Audit log
5vrajasekaran
When I tried to FTP a file to a certain location am getting this error FTP JOB Failed : An I/O exception occurred.; whereas when I check in audit log I see a description "problem with spool file for job". When I tried to connect the host in FileZilla I could able to connect with the port number 990. Can someone help me to fix this?
7 Replies 7
Dan Lukes
Wrong community and you didn't specified what product you are speaking off. Very little chance you will got a valuable response ...
I amusing tidal enterprise scheduler.I got this error when I try to transfer a file to a FTP site.
Then use blue [ EDIT ] button on top of page to move this thread to Tidal Enterprise Scheduler community.
I could not locate Tidal Enterprise Scheduler in the community drop down list
Data Center -> Intelligent Automation -> Tidal Enterprise Scheduler
Thanks Dan Lukes! Posting made it here.
Hi 5vrajasekaran,
Please check out, http://www.cisco.com/c/en/us/td/docs/net_mgmt/datacenter_mgmt/Tidal_Enterprise_Scheduler/6-2/user/guide/Cisco_TES_6-2_User_Guide.pdfhttp://www.cisco.com/c/en/us/td/docs/net_mgmt/datacenter_mgmt/Tidal_Enterprise_Scheduler/6-2/user/guide/Cisco_TES_6-2_User_Guide.pdf
Problem with spool file for job %%1
2102 There was a problem with the job script or the environment file for the given job:
  • The job’s script file does not exist or cannot be read.
  • The job data string sent by the master was corrupt.
  • There was an error transferring the job script from the master to the agent.
  • There was an error transferring the environment file from the master to the agent.
Post back if you need any further assistance.
BR,
Derrick Au
I found this documentation as well, however there is no information on troubleshooting this error.
I am having this same issue, has anyone been able to resolve this?  Can someone please post a solution if available?
One of my FTP jobs which has been running normally for over a year has just started throwing this error.
