Question about Scheduled Task
Daniel Faust
RequestCenter 2008.3
Oracle 10g
Websphere 6.1.27
IE 7
Hi:
I have tried to get a scheduled task to work without any luck.  I am referencing a date/time field on the form and the task goes to "Scheduled", but never moves to "Ongoing".
I've opened a case with support, but was wondering if anyone has gotten this to work.
Thank you
Daniel
Safeway Inc.
Darryl Kinley
Hi Daniel,
We are successfully using scheduled external tasks to create Remedy service requests, but did run into similar issues.  For us it turned out to be a conflict in Queue calendar hour settings.  Setting all queue calendars related to the process to 24x7 seems to have resolved the issue for us.  I hope this was helpful.
Darryl
Kaiser Permanente
Darryl Kinley
In trying to provide a complete answer, I thought I should also add that the queue calendar changes will, of course, force updates to tasks durations for any tasks assigned to the queues you have changed.
Darryl
We just went through this too. If the plan is fairly complex, and has allot of conditional tasks you will have difficulty.
The explanation I got from Shweta is that the calculation that determines the OLAs before my scheduled task was to start looks at ALL the potential tasks and combines them, essentially saying the duration is much longer than what you think it should be, ie the sum of all potential task OLAs, not just the tasks that became active.
Bottom line if your scheduled date is with
Daniel Faust
thank you all - this information is very helpful.
Daniel
