Questions on file transfer capabilities
1. We have a need to move files (multi-mega bytes) from one Unix system to another. 'GetFile' and 'PutFile' seems to use Tidal Windows system as a go between. Is there a way to accomplish unix to unix file transfer without going through Tidal Windows system?
2. When we execute a script using 'Execute Terminal Command' activity, the output of the execution is captured in the activity's 'output' buffer. Won't this buffer overflow when it attempts to capture multi-megabytes output? Assuming it overflows, is there an alternative? If it doesn't overflow, then is there a limit to the multi-megabytes that can be captured in the 'output' buffer?
3. Does Tidal support browser based GUI?
thanks.
Shaun Roberts
1. Probably need dev input on this... the activities do have to run on the orchestrator server
2. the buffer should be ok I think, i've never seen anyone "break" it, but if you do, open a ticket and we can work with dev
3. CPO has a web console. by default it should be @ http://:2081/TEOWebConsole
The webconsole is a "toned" down version of the master UI.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
