Upgrade path from CCP 9.3R2 to 9.3.2
Satish Pilla
Hi Team,
Can someone help on the process involved in upgrading a CCP9.3 R2 environment to 9.3.2.
Is the upgrade faily straight forward or do we have to do some customizations to make this happen??
I have a CCP 9.3R2 and CPO 2.2 in a DEV system, have lot of custom content in this environment.
I am upgrading CPO 2.2 to CPO 2.3 engine but not importing the content because I have custom content built on 2.2.
I am liking to know the process doing an upgrade for CCP
- is the inplace upgrade of CCP 9.3R2 to 9.3.2 valid???
OR
- building new CCP 9.3.2 and export / import content from 9.3 R2 to 9.3.2 valid??
Satish
Shaun Roberts
CCP upgrade should be straight forward. Refer to the CCP doc for upgrade paths and instructions. You would have to test the content you built in 9.3 R2 as I do not know all the inner parts difference in the two versions.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
