Reducing WSDL Size
david.hout
Is there a way in teo to control which processes end up in the wsdl for the Northbound Web Service?  It seems like this should be an option on a process by process basis but I can't seem to find it.
As it is the wsdl is pretty large with a lot of stuff I don't need.  I know I could manually edit the wsdl but it doesn't seem like that is the best way.
Dave
Shaun Roberts
David,
Yes there is.
Look in the web service documentation. There is a trigger which controls whether a process can be invoked ad hoc. Without the trigger it is assumed the process is intended to be called by others as a child. The processes without this trigger are filtered from the lists when starting ad hoc and are not available from the web service.
-Shaun Roberts
CIAC/CPO Support Team Lead
shaurobe@cisco.com
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Shaun,
Thanks for the help.  I tried this but must be missing something.  As an example I have an automation pack installed (probably from you) called VBLOG DEMO - Process Authoring - Monitoring TEO.
I edited each of these processes and removed the "Started by User" trigger.  I then went into File - Server Properties - Web Service and clicked on the "Refresh Web Service" button.  The attached screenshot shows those processes in my "Definitions" view.
In my browser I went to http://:61527/WS/Process?wsdl
The wsdl still had references to the VBLOG DEMO processes.  I cleared my browser cache just to be sure and saw the same result.  As a final step I then restarted the TEO server and cleared my browser cache but no matter what I do I still see those processes in my wsdl.
Dave
saw this as well when I tested. I will check back with development.
-shaun
--Shaun Roberts
shaurobe@cisco.com
