Run Options In Reporting
I'm trying to create a custom report to automatically produce output in excel format; however, when it runs it defaults to HTML.  When you click "Run with Options", the only 2 format options are HTML and PDF.  Is it possible to show excel as an option or is it a limitation in the RequestCenter/Cognos implementation.  I've seen this option available in other Cognos environments not related to RequestCenter.  Please see attachment.
You are correct, Liz. This Cognos option was not incorporated by newScale into the RC06 or RC07 reporting implementation. It is being incorporated into the RC08 reporting.
wwesley
null
