Scan Output:P Abnormal String. Error not setting job to Completing abnormally
jeff.hamway01
Hello Fellow WLA,
I have a Tidal job that is setup to complete abnormally if "exception","error" are displayed in the output.  For some reason it still showing as completed Normally when the key word 'Error' is displayed.
I was unable to find any information in the documentation if the string information is case sensitive.  does anyone know?  I have attached the error output and the settings for your review.  thanks in advance as always.
Tidal 6.0.3
Windows VM
Jeff hamway
Derrick Au
Level 4
Level 4
Hi Jeff
If the abnormal string is enclosed by quotation marks then it is actually case-sensitive. If you remove the quotation marks, then whenever it encounters exception / error, then your job will be flagged as completed abnormally
BR,
Derrick Au
Derrick Au
Level 4
Level 4
Hi Jeff
BR,
Derrick Au
Wow. interesting. thanks for the insight.  As always, your the man.
