SQL 2014 Compatibility?
Scott Gillmore
Community Member
Can anyone tell me if 5.3.1 or 6.2 are compatible with SQL 2014?  We're currently running 5.3.1 while considering upgrading to 6.2, but we're upgrading our databases at the same time, so I need to which aspects of each version are compatible with SQL 2014 to know if the databases will need to run in compatibility mode.  We use SQL as a back-end (Admiral) as well as a number of SQL Adapter connections.
6.2.1 SP2 is compatible with MS SQL 2014
See the doc at
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/datacenter_mgmt/Tidal_Enterprise_Scheduler/6-2-2/compatibility-matrix/TES_Compatibility_Matrix_1-0-0_08Jun2015.pdf
