TES 6.1.x - how do you tell what DB is used by ClientMgr?
Lumi Mihalcea
We just externalized the Client Mgr DB to Oracle, updated config files, etc. How do you tell what db is using - Derby or Oracle?
John Laird
After you externalize the CM database, you should see the db objects (tables and views) in the database are now created shortly after you start the CM service.
You can verify creation of database objects in the actual database and in the plugin log upon start-up. This log can be found  under the ../ClientManager/plugin/tes-6.0/log directory
John
