TES 6.1.x - custom date format
Lumi Mihalcea
In 5.3.1. I was able to create my own custom dates. In 6.1 I create the format, click on Add Custom Format - click OK. When I go back to Variables - System Variables - System Date - Date Format I expect to see it in the list so I can select it, but it's not - I have to do all the steps all over again. Is this some kind of bug or is just me?
Marc Clasby
I think this is a bug and the behavior seems different than 5.31
(I just installed and starting working with 6.1 the past couple of days)
CMD powershell.exe
PARAMS write-host JobParent JobName for and today minus one days is
You seem to be limited in custom format choices but I know how dates are supposed to be formatted after the variable number or sydate. TodayMinus1 is a calculated date variable
the output is correct but they you now have to remember to go back in and modify variables instead of selecting
Marc
Tech Support told me to download the latest hotfix TES_610_HotfixBundle_03062013.zip which fixes the issue with custom date format
Build  6.1.0.199 of TESPlugin and TESWebClient
CSCue31575:  6.1 Customer date formats do not persist
Problem    : When using Scheduled Date from Job run variables, the custom date formats that  you add do not persist. User has to re-enter the 'Add Custom Format' each time.  i.e. using format YYYYMMDD requires you to add that custom format every time  instead of being able to either free form in the 'Date Format' field like you  can on 5.3.1 client, or making it available from 'Date Format' drop down like it  did on 5.3.1 client.
Solution   : Now saving the newly defined custom date formats in user preferences so that  they can be available after the creation. these will added to all date type  variables.
Weird
I am going from base 6.1.0.133 release to the March bundle
After applying the bundle, according to the read me I think I should be at:
Master 6.1.0.198
Client Manager which I assume = TESPlugin and TESWebClient
From logs
Client Manager
Client Manager version: 6.1.0.138
Java version: 1.6.0_43
Java Virtual Machine version: 20.14-b01
TIDAL Enterprise Scheduler: version 6.1.0.189
Adapter Host: version 6.1.0.133
Master
Adapter Host
Job Adapters
JDBC Adapter 2.1.0.192  <-- I don't see this in March bundle (is there another bundle?
All my other adapters seem to be correct based on readme.
Any tricks I am missing I replaced all the files in the appropriate area w/ services stopped and restarted
