Tidal 6.1 Transporter Error: OutOfMemoryError: Java heap space
salam2010
After connecting to source and destination, when I hit "Read Data" the transporter showed me the below error:-
"Error reading Data from Source and Destination:OutOfMemoryError: Java heap space"
Transporter version is : 6.1.0.371
Client Manager version :6.1.0.388
Master version: 6.1.0.387
Transporter is installed on windows server 2008 64 bit OS with 16 GB memory
Can anyone provide any suggestion about the error and its solution.
Is ther any way to specify the JVM memory in transporter.props file?
Thanks.
Hi there, saw this in one of our guides:
Need to configure memory for Transporter.  C:\Program Files\TIDAL\Transporter\bin\transporter.cmd  Edit the line:  "%JAVA_HOME%\bin\java" -Xms6g -Xmx6g -DTIDAL_HOME="%TIDAL_HOME%" -jar "%TRANSPORTER_JAR%" %*
Default is -Xms256m -Xmx512m
For our Transporter server it is I changed it to -Xms6g -Xmx6g
Will need to throttle this down in a multi concurrent user environment.
Thanks, Carolanne.
We found each user connection to Transporter takes about 500 MB of memory and we have bumped up to 2048 for both min and max memory.
Saif
