Tidal Connection to db
Raj Annadorai
Is it possible to change the password for Tidal Schema and update it in the connectivity?. We do not want to keep the standard password and not sure where to update the changed password in the setup. Anyone has done this?
Raj
bluehouseinc
Yes, this is possible and assuming your running TES 5.x in the reference guild.pdf page starting on page 508 has the instructions to make the changes.
Before changing the database password, stop all masters and close all clients. Be sure to run the SaPasswd utility on all client and master machines.
Any utility or client connecting from a single workstation to multiple databases must use the same database password.
We are running master master version: 6.0.3.186 . I am not sure if the procedure is different for this version. Let me know and i will follow the steps.
