Job Status is Completed Abnormally .
Binu_Cherian
       Job Command is D:\PSTARDEV_BACKUP\backup.cmd ..
Output of the Job
                 Total       Copied       Skipped         Mismatch             FAILED              Extras
Dirs :        10413       0              10413             0                          0                         0
Files :       78850    18001         60849             0                          0                         0
Bytes :     3.319 g 1.274 g        2.045 g           0                          0                         0
Times :     1:57:56 1:05:56                                                        0:00:00                 0:52:00
Speed : 345883 Bytes/sec.
Speed : 19.791 MegaBytes/min.
Ended : Thu Jan 03 00:55:51 2013
Completed at 1/3/2013 12:56 AM
Does any one know  why is status of the job is completed abnormally when actual job is finishing with out any error's..  ?????
Marc Clasby
That looks like Robocopy to me so I think the Extra files has it exit with a non-zero exit code (If my memory serves me right)
Can you give us more information (what is command / params) In job actitivy thestatus page will tell you the exit code and the job definition run tab "tracking section" will tell you how it evalutates the exit code (or alternative)
Marc , Thanks for the Reply ..Job has a Exit Code of 1
Command of the job  is  D:\PSTARDEV_BACKUP\backup.cmd and there is no parameters. It's run on a windows agent.
Tracking Use : Exit Code (normall = 0 to 0 )
gjensen
Robocopy has numerous exit codes. exit code zero indicates source and destination match and nothing needed copied. Exit codes 0-8 are non-error exit codes depending on what you're trying to do. REF:http://support.microsoft.com/kb/954404
So if you only want to fail on errors, set your successful exit code range 0-8.
But if the destination directory should never have a file that isn't in the source directory, set the exit code 0-1 since exit code 2 indicates files in destination that are not in source location but robocopy doesn't error and still copies files.
