Tidal Transporter Automation through Linux
sheenghese1
Is it possible to call a shell script in Linux to invoke transporter action,transport jobs from one environment to another ?I guess it should access the repository to perform the above.
Sheenghese
Is it only one transporter action that is required to be invoked ?
If yes, the command line invocation section in the Transporter user guide should be able to guide you
Normally, we end up performing multiple actions using the Transporter GUI depending on the type of artifacts that are being transported
