tidal with SSIS
coool_sweet1
hi
i need to schedule my ssis using tidal,
i dont know what parameter i need to pass to command.
after seeing other packages they are passing .exe file, my question is do i need to create this file,whats purpose of this file and how can i create it.
i have 1 parameter in my ssis package
18 Replies 18
what i have is following commnad for tidal to run ssis job.
        Jobname: 01_product
·         Program command:  c:\Applications\SQLJob\SQLJob.exe
·         Program command parameters: Server=dayssis01  I=20 Job = Product
·         Capture Alternate Output File:
·         Schedule: AD HOC
·         Run Agent: day-05
·         Runtime user: local
my question is what is  c:\Applications\SQLJob\SQLJob.exe
here and how to create and use it.
i have my package in 2012
Sorry that does not ring a bell. My guess is that either
1. The requester of the job has created a custom .exe that you can invoke. So I would suggest you login to the server your windows agent is planned to run, and confirm if c:\Applications\SQLJob\SQLJob.exe exists on that server
OR
2. The requester may not be aware that Tidal can invoke SSIS jobs using 3 other options(command line or stored procedure or SQL job). You may need to educate the requester and obtain updated command to trigger specfic SSIS job using any of the 3 alternatives
@Dave.Carnahan
I am referring attachment png file beginning with the name 'DOS.xxx' and i have below doubts.Input will be appreciated
1)Could you please provide details and code for what i need to mention in 01_Tidal_Env.Bat file and also where i need to place this file
2)What is SSID.DtsConfig and where this file is present?
Hi Coool_sweet,
One way you could do this is as follows:
1.  create a job on a windows agent
2.  command:  cmd.exe
3.  parameter:  /C \\path\to\batch\file.bat
4.  file.bat file contains something like this:
@ECHO OFF
DTEXEC.exe /FILE "\\path\to\file.dtsx" /argument1 /argument2
where:
a) your dtsx file is an integration services package you can create/edit with Microsoft Visual Studio
b) /arguments are optional depending on the package you have created
