Need help on Rest API call
msivarami3
Please provide some steps how use the Rest API call CPO.
My requirement: Need to access Service Item from portal and get/update. some information using REST API (if any other solution provide it).
Thanks and regards,
Vignesh
6 Replies 6
Shaun Roberts
If you want to call into CPO, use something like SOAP UI and plug into CPO's NBWS and then you'll get the XML payloads.
If you want to call out of it, use the HTTP request activity.
otherwise if you need more help and you have a support contract, open a TAC case.
-shaun
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Hi Christopher,
Thanks for reply.
When i use HTTP reqest activity i am getting this error as below:
Unable to fully resolve expression, as Reference to Property ResolvedUser.Id of ProcessInstance . could not be resolved.
Relative Url Syntax:
http:///RequestCenter/nsapi/serviceitem//?Condition
Eg:
http:///RequestCenter/nsapi/serviceitem/SiDynamicDataCenterPilot/Name?ciacDDCID_PK=CBU:None:DDC5
Method: GET
Version: 1.1
Target: Cisco Cloud Portal Request Center API
Provide some inputs to resolve this.
Hi Christopher,
Thanks for reply.
below is my requirement:
Need to get Service Item data using CPO process.
1) Is there any way to get Service Item information in CPO?
If it is the Web HTTP Request, is there any wsdl url to access service item?
CCP Providing RES API to acess the si data below is the url for it.
How to use this in Web HTTP Request CPO activity to get the xml data ??
Sivaram
yes there is. This is the way CIAC 3.0 or 3.0.1 works. You should look in that content for examples. I will not paste examples here as that's developed information and this is a public forum. If you have the CIAC 3.0+ content look in the Export Service Items process and you'll see how it has been developed. If not, then you need to get that content.
--Shaun Roberts
shaurobe@cisco.com
Thanks Christopher,
I have verified the Export Service Items process and tried an example as follows:
1) Establish Session ID
2) Login
3) Query the Service item.
When i run the process I am able to complete the first 2 activities and in 3rd step unauthorizaion exception was occured.
Error message:
       The remote server returned an error: (401) Unauthorized.
       User does not have proper authentication..
When I tried in explorer with same query it is able to get XML as ouput.
What might be the error in this scenario? Is is it related to CCP admin previlages or it is from CPO end?
Please provide some inputs to resolve this?
Thanks and regards,
sivaram.
you need to make sure you are passing cookies properly from the login on. Also what user are you using?? It is the same one?
In standard CIAC, the NSAPI user must be a member of the site administration group, CPTA group, and site admin OU, and CPTA OU with the CPTA OU being their home OU.
--Shaun Roberts
shaurobe@cisco.com
