Usage of REX Adapter
manasarn1
Hi team,
Could you please provide inputs on how to use REX Adapter for creating users and assigning roles to them.
Thanks in advance.
Tuan Tran
What is a "REX" adapter?
Shaun Roberts
I would suggest looking at the services in the portal to see how the adapter is used. It is an adapter in Cisco Prime Service Catalog only and not in Cisco Process Orchestrator. There is plenty of examples of it out of the box in the CIAC solution. Can you check in there?
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
I see.  Perhaps this thread should be moved to PSC or IAC forum where it can get better response?
