Using Command Line to move objects from one environment to another enviroment
Reginald Hill
Can the Command Line (sacmd) be used to move Job Groups/Jobs and other object from one environment to another environment? If so, how?
Brian Dickens
Moving jobs and objects can only be accomplished by using the Transporter application. There is a document called "Transporter User Guide" with a chapter called "Running Transporter in Batch Mode" that details how to send commands to transporter from the command line. It also details how to setup jobs in Tidal to use this command line. Once you have jobs in Tidal using the Transporter command line, you can then use sacmd to run these jobs.
Does this make sense?
