Moving jobs and objects can only be accomplished by using the Transporter application. There is a document called "Transporter User Guide" with a chapter called "Running Transporter in Batch Mode" that details how to send commands to transporter from the command line. It also details how to setup jobs in Tidal to use this command line. Once you have jobs in Tidal using the Transporter command line, you can then use sacmd to run these jobs.
Does this make sense?
