Intersight polling
cchavez
Hi All,
How often does Intersight poll UCS? I ask because i upgraded UCS firmware to 4.0(2d) and Intersight is still showing the old 3.2 firmware. Im going to deploy HX using Intersight and not sure how this impacts that deployment. Any help would be much appreciated.
mohammar
Not sure how often polling occurs but you can continue with the HX Installer via Intersight. During the Deployments process it'll validate both Infra and Server bundles against HXDP. You can always restart the Deployment where you left off even if there are errors. HTH
mohammar
Hi mohammar,
Thank you. I moved forward with the install and got it stood up. Firmware is still showing the older firmware version. Perhaps this will be fixed later on.
