09-16-2011 12:07 PM - edited 03-10-2019 05:28 AM
I have a high value for Global Correlation parameter, which I generated my ips module is alarmed, how I can reset this value?
Additionally, the automatical updates does not work properly in the module. What could be the problem?
Thanks for you help.
09-17-2011 07:00 AM
Ensure dns is configured on the sensor. It will need to communicate to receive updates. also ensure you have a valid license.
09-19-2011 08:16 AM
I have configured local and public dns but does not work yet.
