FirePOWER, Do i need a management server.
Mark.Smith1969
Soory simple question but i can't find an answer. I have never worked with an ASA with FirePOWER before so not sure what you get.
It it possible to manage FirePOWERfeatures without installing the management server appliance?
Mark.
Marvin Rhoads
It depends.
Originally only the 5506, 5508 and 5516-X appliances with FirePOWER 5.4+ could be managed strictly with ASDM. FirePOWER 6.0 extended that capability to all the ASA appliances as long as you had the right releases of FirePOWER software and associated ASA / ASDM software.
However you still have some limitations - reporting, event storage, some advanced configuration options etc. are all lacking when using ASDM. All the basics are there but it's frustrating to run into one of those limitations when the small management VM (2 device license) is only US$500 list price (net price usually less).
Also, if you manage anything beyond a single ASA with FirePOWER you usually want the FirePOWER Management Center so you can create one policy (or set of policies) and deploy to all your modules.
Marvin Rhoads
It depends.
Thanks Mavin
