08-05-2010 10:26 AM - edited 03-10-2019 05:05 AM
I have a 4255 IDS/IPS sensor running v7.04, everyday at 2pm it is doing something that causes it to either reboot or stop passing traffic long enough for my firewalls to think that I am no longer passing traffic which forces them to fail-over. I have looked at the auto updates and they are not scheduled to run, I have tried to look to see if there are any events that are happening during that time and I can find nothing. I do not know if there are more comprehenisve logs that I should be looking at but if someone can offer suggestions I would be greatly appreciative.
08-09-2010 03:01 PM
Torsten,
The things that could potentially cause the IPS to go into bypass which could in turn potentially cause the ASA's to failover are as follows:
Configuration Changes
Auto Updates
Global Correlation Updates (5 minute intervals)
Anomaly Detection
As a test you might want to turn off global correlation and anomaly detection and see if the issue persists. Below are the instructions to turn these options off:
Next is an example by using CLI to turn GC and AD off:
# -------------- To turn off global correlation inspection
sensor-43# config t
sensor-43(config)# service global-correlation
sensor-43(config-glo)# global-correlation-inspection off
sensor-43(config-glo)# exit
Apply Changes?[yes]: yes
#-------------- To turn off network-participation
sensor-43(config-glo)# network-participation off
#-------------- To turn off AD
sensor-43(config)# service analysis-engine
sensor-43(config-ana)#virtual-sensor 0
sensor-43(config-ana-vir)# anomaly-detection
sensor-43(config-ana-vir-ano)#operational-mode inactive
sensor-43(config-ana-vir-ano)# exit
sensor-43(config-ana-vir)# exit
sensor-43(config-ana)# exit
If the issue still persists after ensuring that all the above is off you might want to gather a show tech output. In the show tech output search for the word "main.log" and start searching via the time stamp for any messages around 2:00pm. Also what is your bypass mode set to (auto,on,or off)?
I hope the above helps!
Justin T.
08-09-2010 03:12 PM
Hello Torsten,
You mention that the IPS inline with the active firewall reboots, or stops passing traffic. Do you mean that you are not sure which? If so, you can check the sensor up-time in the output of a "show version."
Would you mind forwarding a "show tech" for us to review?
Thank you,
Blayne Dreier
blayne@cisco.com
Cisco TAC IDS Team
**Please check out our Podcast**
TAC Security Show: http://www.cisco.com/go/tacsecuritypodcast
