PROTOCOL-DNS dns response for rfc1918 Violation
Hello all
We are in the middle of deploying an FTD with IPS for a project. We have seen a large number of the following violations in the IPS event log:
Message
Priority
Classification
PROTOCOL-DNS dns response for rfc1918 172.16/12 address detected (1:15934:11)
high
Potential Corporate Policy Violation
PROTOCOL-DNS dns response for rfc1918 10/8 address detected (1:13249:14)
high
Having read the SNORT documentation for each of these I think I know what the issue, but my confidence level is not very high & would appreciate some advice from some more seasoned veterans.
Our setup is such that we have defined our HOME_NET variable as the 10/8 network, and left the EXTERNAL variable at 0.0.0.0/0. What seems to be triggering the above violations is when a server receives a response to a DNS query that contains a 172.x.x.x address. I think it may have something to do with how we have set our variables. Could it be that adding the 172/12 network to our HOME_NET variable set could fix this issue?
Thank you.
pazzi
Hi Devlin
Your home_net should include all the network addresses that this sensor is protecting.
Your external_net should exclude your home_net.
Thank you pazzi for your swift response
That was as I suspected, partly. The 172/12 is legitimately part of our internal network so it makes sense we would include it as part of the HOME_NET variable. I say partly as I wasn't aware we would also need to explicitly exclude it from the EXTERNAL variable.
In your opinion does it make sense that the violation we are seeing is therefore a result of not setting our variable set(s) correctly?
Thank you.
Yes, could be.
Many snort rules trigger based on server replies.
Incorrect values to variable sets can generate false positives.
Paul
Thank you Paul
Appreciate the speedy responses. We'll look into this and update this thread with the findings.
