CCM cli usage
mcecilia
Level 4
Level 4
Hello all,
I have runned the following command:
utils dbreplication status all
And receive the following message:
Output is in file cm/trace/dbl/sdi/ReplicationStatus.155220.out
How can I see this file? I have tried with RTMT with no success.
Many thanks
Tommer Catlin
If you are in RTMT, just click on Database Summary and it will see the status of the DBs.
each server in your cluster should have "2". If they have other numbers, you have issues.
Tommer Catlin
