취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
Is it possible phone users can use pin code when calling NDD/IDD numbers as substitute to FAC during SRST mode?
giodias01
One of our client is asking if there is possibility that we can use Pin code during SRST mode.I think FAC only use for CUCM only, please correct me if I'm wrong. They used Cisco 3925 with IOS version 15.4M1.
Gritzen
5 응답 5
Jaime Valencia
If you mean the FAC that is in CME, you'd probably need to use CME-as-SRST in order to use it, not just SRST. And you would need to manually configure the users and codes in that scenario.
java
if this helps, please rate
Hi Jaime,
Thank you for the quick response. Our client used their Voice Gateway 3925 as SRST. Did you mean that they cannot use FAC during SRST mode? How can I determine if it is configured as SRST only or CME-as-SRST?
Thank you
Amit Sharawat
You can use FAC if you are using CME SRST as per the document:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmefac.html#pgfId-1011683
However, if you are call-manager-fallback mode, we wont be able to configure it.
~Amit
Hi Amit,
This means that we cannot use FAC pin code if it is plane Voice Gateway only as SRST not CME SRST.
Thank you
Yes, the call-manager-fallback SRST has very limited functionality, however the CME SRST is full fledged SRST with almost all the CME features.
~Amit
