Unity Messging Server Problem
vraghu
Community Member
Dear Sir,
I have Cisco Unity 4.0.5 and the C drive is out of space there is a folder size of which is 11.6 GB and the path of that folder is as below.
C:\Program Files\Microsoft SQL Server\MS SQL\Data\UnityDb_Log.LDF How can I decrease the size of this file becuase Unity is stoped and its not working.
shankar1023
jfenner
Community Member
Yes, you simply need to shrink the transaction log. Check with google, and you will find plenty of resources that tell you how to do this. Also, you can set up a scheduled DTS job that will shrink it on a regular basis.
Tommer Catlin
If you have a D Drive, move the LDF and MDB to that drive. There are procedures on how to move SQL databases to new or larger drives.
