Cisco 1921 IPV6 issue
mgraham94
Greetings...I have a Cisco 1921 with one EHWIC-D-8ESG module installed.
I have a test system where I have to use static IPV6 addresses on the connected devices, all these devices are connected to the EHWIC ports.
I can ping these devices from the router, through the EHWIC, but I cannot do a device to device ping. IPV4 ping work fine in either direction. Here is my configuration file.
19 Replies 19
Marcin Latosiewicz
Mike,
I'm not aware of any additional requirements to be put on L2 ports to support IPv6 (in theory there should be none exactly like for IPv4). I'm also not aware of this module not being supported with IPv6.
I assume you checked:
- for DAD failures
- ping not only between assigned addresses but also between link-local
- neigborship table on the devices.
Quite honestly I would start by sniffing traffic to see if the router is just consuming network discovery packets.
Marcin
I'm having the same issue - IPv6 works fine from hosts on the LAN towards the internet and from hosts to the router itself, but local traffic between hosts connected to the EHWIC-8ESG-P is not working. None of my hosts can reach each other directly. I'm currently doing some investigations, but so far I have not had any luck finding a solution. I have a feeling that IPv6 packets aren't being correctly processed by the switching engine when the destination is something else than the router itself (SVI in my case). Alternatively it may be related to the handling of multicasts (my end hosts are not seeing the ICMPv6 NS messages at all), but both of these only a hunch as of now, since I have yet to find any real proof of it .
The problem exists under both 15.1(4)M1 and  15.2(1)T.
If anyone has suggestions, feel free to chime in.
Cheers,
Mark
Mark, Mike,
Looks like this is something symptomatic.
I think it's best to open a TAC case so we can look into this ASAP, it's either a software bug or lack of documentation (in which case it's a documentation bug).
Marcin
Agreed. I've not been able to make any progress at all. I'll create a TAC case right away.
/Mark
Mark,
Can you give me the number? I'd like to spy on it ;-)
M.
Sure - I'd like to, but my CCO login has apparently never been associated with the relevant service contracts, so I can't create the TAC case as the serial number of the router is out of the perimeter of my profile.
I'll have to get that sorted out first - hopefully I can get that done quickly.
/Mark
Mark,
Can you check for me "show controllers" for the interface you have IPv6 enabled?
This is a proper output, we see that the device will accept mcast addresses.
GM#show controllers e 1/0
Interface Ethernet1/0
Hardware is AMD Unknown
ADDR: 327DF38, FASTSEND: 1A2D14, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 11
amdp2_instance=0x327EFE8, registers=0x327DEE0, ib=0x327F498
rx ring entries=32, tx ring entries=64
rxring=0x327F4E8, rxr shadow=0x327F720, rx_head=0, rx_tail=0
txring=0x327F7D8, txr shadow=0x327FC10, tx_head=0, tx_tail=21, tx_count=21
Software MAC address filter(hash:length/addr/mask/hits):
  0x01:  0  3333.0000.0001  0000.0000.0000         0
  0xC0:  0  0100.0ccc.cccc  0000.0000.0000         0
  0xC5:  0  0180.c200.0007  0000.0000.0000         0
  0xFE:  0  3333.ff03.6601  0000.0000.0000         0
  0xFE:  1  3333.ff00.0001  0000.0000.0000         0
Marcin
Hi Marcin,
It doesn't give any (useful) information:
AR1#sh controllers gigabitEthernet 0/1/2
Controller GigabitEthernet0/1/2
PHY registers :
  Copper ctrl reg (reg 0 ) is      : 0x1140
  Copper status reg (reg 1 ) is    : 0x796D
  Copper ctrl reg1 (reg 16) is     : 0x3360
  Copper status reg1 (reg 17) is   : 0xAF48
  Interrupt ena reg (reg 18) is    : 0x404
  Copper status reg3 (reg 26) is   : 0x9040
I'm still struggling to get my CCO account setup correctly, so I can create the TAC case.
/Mark
All
Here is what I see when I run wireshark
When I ping from device 1 to device 2's IP v6 address fd00:0:20:1::4, device 1 multicast neighbor solicitation to try to resolve the MAC address of fd00:0:20:1::4, however I don’t see a neighbor advertisement sent back, so it is possible that somehow the router(with the embedded switch ports) doesn’t forward the multicast packets.
Here is a whole com log capture of the router version and the show controller port.
Console # show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
System restarted at 14:39:32 UTC Mon Sep 26 2011
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M1.bin"
Last reload type: Normal Reload
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FTX1532814H
10 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID   SN
*0     CISCO1921/K9          FTX1532814H
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
Console# show controllers gigabitEthernet 0/1/0
Controller GigabitEthernet0/1/0
EHWIC registers:
  id                : 0x00000002,   rev               : 0x00000000
  status            : 0x00000000,   control           : 0x0000CA00
  Interrupt Event   : 0x00000000,   scratch           : 0x00000000
  Fatal Error       : 0x00000000
  Low level status  : 0x0000080C,   Core reset control: 0x00000000
  NIOS reset control: 0x00000000,   NIOS PC           : 0x00205260
FPGA registers:
  Hardware/Version        : 0x0C030600,  NIOS II Interrupt status: 0x00002000
  NIOS II Interrupt enable: 0x00001808,  NIOS II Interrupt test  : 0x00000000
  Host interrupt status   : 0x00000400,  Host interrupt enable   : 0x00020A80
  Host interrupt test     : 0x00000000,  Reset control           : 0x00000000
  SRAM parity error addr  : 0x00000000,  SRAM parity error data  : 0x00000000
CMD Queue:
  Read Index: 14, Write Index: 14
IRQ count:
  Host to NIOS IRQs: 0, PHY IRQ: 2, Switch IRQ: 0
  POE IRQ: 0, Other NIOS IRQs: 0
NIOS:
  SMI read count: 2965, SMI read errors: 0
  SMI write count: 4201, SMI write errors: 0
  DMA Q count: 0, DMA Q Max count: 3, DMA IRQ: 336
  PHY read errors: 0, Link Event errors: 0
  I2C read count: 0, I2C read errors: 0
  I2C write count: 0,I2C write errors: 0
  I2C reset count: 0,I2C reset fail: 0
  Stats IOS busy: 0, Stats data err: 0
ESWGE FPGA VERSIONS in hwic slot 1
  Golden area fpga version:  00030600
  Upgrade area fpga version: 00FFFFFF
  IOS bundled fpga version:  00030600
  Running fpga version is :  00030600
BPSM counters:
  0 from invalid slot, 0 not for CPU, 0 Unknown packet, 0 Invalid output packets
GigabitEthernet0/3 is up, line protocol is up
  Hardware is Backplane CN Gigabit Ethernet, address is 30e4.dbe0.b1c3 (bia 30e4.dbe0.b1c3)
  MTU 9576 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full Duplex, 1Gbps, media type is internal
  output flow-control is unsupported, input flow-control is unsupported
Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
CPU port:
Statistics for slot:1, switch port:9
30 second input rate 0 packets/sec
30 second output rate 0 packets/sec
0 packets input, 0 bytes, 0 overruns
Received 0 broadcasts, 0 multicast, 0 unicast
0 runts, 0 giants, 0 jabbers
0 input errors, 0 CRC, 0 fragments, 0 pause input
0 broadcast, 0 multicast, 0 unicast
0 late collisions, 0 collisions, 0 deferred
0 bad bytes received, 0 multiple, 0 pause output
Switch egress queues drop count register(READ CLEAR): 0x0
PHY registers :
  Copper status reg (reg 1 ) is    : 0x7949
  Copper status reg1 (reg 17) is   : 0x8010
  Copper status reg3 (reg 26) is   : 0x9140
It gives more detailed info when performed on the first port (Gi0/1/0):
EHWIC registers:
  Low level status  : 0x00000808,   Core reset control: 0x00000000
  NIOS reset control: 0x00000000,   NIOS PC           : 0x00206E70
FPGA registers:
  Hardware/Version        : 0x08030600,  NIOS II Interrupt status: 0x00002000
CMD Queue:
  Read Index: 54, Write Index: 54
IRQ count:
  Host to NIOS IRQs: 0, PHY IRQ: 35, Switch IRQ: 307
NIOS:
  SMI read count: 4234, SMI read errors: 0
  SMI write count: 5457, SMI write errors: 0
  DMA Q count: 0, DMA Q Max count: 5, DMA IRQ: 490359
  I2C read count: 367531147, I2C read errors: 0
  I2C write count: 17710,I2C write errors: 0
POE Registers Device 0
  Device ID reg:     0x51    Power event reg:  0x0
  Detect event reg:  0x0     Fault event reg:  0x0
  Start event reg:   0x0     Supply event reg:  0x2
  Port1 status reg:  0x34    Port2 status reg:  0x64
  Port3 status reg:  0x1     Port4 status reg:  0x1
  Power status reg:  0x33    Pin status reg:  0x1
  Operating mode reg: 0xAA   Disconnect enable reg: 0xF0
  Timing cfg reg:  0x0       Misc cfg reg:  0xA0
  Mode 3 reg:    0x0         PWR Priority reg:  0x0
  ICUT p1p2 reg: 0x22        ICUT p3p4 reg:  0x22
  IDC p1 LSB:    0xDC        IDC p1 MSB:    0xB
  VDC p1 LSB:    0xDC        VDC p1 MSB:    0x22
  IDC p2 LSB:    0xCE        IDC p2 MSB:    0x5
  VDC p2 LSB:    0xBF        VDC p2 MSB:    0x22
  IDC p3 LSB:    0x0         IDC p3 MSB:    0x0
  VDC p3 LSB:    0xC9        VDC p3 MSB:    0x2
  IDC p4 LSB:    0x0         IDC p4 MSB:    0x0
  VDC p4 LSB:    0xBD        VDC p4 MSB:    0x2
  2X PWR reg:    0xF0
POE Registers Device 1
  Detect event reg:  0xF     Fault event reg:  0x0
  Port1 status reg:  0x1     Port2 status reg:  0x1
  Power status reg:  0x0     Pin status reg:  0x5
  IDC p1 LSB:    0x0         IDC p1 MSB:    0x0
  VDC p1 LSB:    0xAD        VDC p1 MSB:    0x2
  IDC p2 LSB:    0x0         IDC p2 MSB:    0x0
  VDC p2 LSB:    0xC7        VDC p2 MSB:    0x2
  VDC p3 LSB:    0xEA        VDC p3 MSB:    0x2
  VDC p4 LSB:    0xBB        VDC p4 MSB:    0x2
  2X PWR reg:    0xF0
BPSM counters:
  Hardware is Backplane CN Gigabit Ethernet, address is 30e4.dbf7.4483 (bia 30e4.dbf7.4483)
  Keepalive not set
  Last input never, output 00:00:00, output hang never
  30 second input rate 9000 bits/sec, 14 packets/sec
  30 second output rate 146000 bits/sec, 20 packets/sec
     1006065 packets input, 121351792 bytes, 0 no buffer
     Received 123735 broadcasts (0 IP multicasts)
     2123337 packets output, 1133642405 bytes, 0 underruns
CPU port:
30 second input rate 19 packets/sec
30 second output rate 13 packets/sec
2123256 packets input, 1142121993 bytes, 0 overruns
Received 2 broadcasts, 1155502 multicast, 967752 unicast
1005913 packets output, 125360494 bytes, 0 underruns
63387 broadcast, 60199 multicast, 882327 unicast
PHY registers :
  Copper status reg1 (reg 17) is   : 0xAC48
But not sign of MAC address filters in the output...
/Mark
Gents,
I do not have a device in the lab with that module and the only way I can request it is via our lab folks but for that we will need a TAC case :[
I guess the problem in fact might be that router will consume L2 mcast rather then forward it out everywhere on the vlan (as Mike mentioned).
I think at this point in time it's best you open a SR.
Marcin
I think we're on the right track - I just did a simple test:
ipv6 access-list MCAST
permit ipv6 any FF00::/8 log-input
permit ipv6 any any
int vlan20
ipv6 traffic-filter MCAST out
Sep 26 2011 21:21:44.510 CEST: %IPV6_ACL-6-ACCESSLOGDP: list MCAST/10 permitted icmpv6 200x:xxxx:xxxx:1:9477:3122:1BD2:6AEF (Vlan20 bcae.c574.94ab) -> FF02::1:FF00:14 (135/0), 150 packets
Sep 26 2011 21:22:44.510 CEST: %IPV6_ACL-6-ACCESSLOGDP: list MCAST/10 permitted icmpv6 200x:xxxx:xxxx:1:9477:3122:1BD2:6AEF (Vlan20) -> FF02::1:FF00:B (135/0), 1 packet
Sep 26 2011 21:22:44.510 CEST: %IPV6_ACL-6-ACCESSLOGDP: list MCAST/10 permitted icmpv6 200x:xxxx:xxxx:1:9477:3122:1BD2:6AEF (Vlan20 bcae.c574.94ab) -> FF02::1:FF00:B (135/0), 1 packet
(The host I'm trying to ping is at 200x:xxxx:xxxx:1::14, which maps to the FF02::1:FF00:14 multicast address)
Traffic is sent out the SVI, but magically disappears somewhere en route towards the interface.
/Mark
Mark,
The thing as I see it. This module is a switch module thus, mcast/broadcast/unknown unicast frames should be sent out all the ports.
Check on SVI is not really a valid test - it might depend on implmenttion. We're talking about L3 SVI and packets which sould be L2 switched (not L3).
Marcin
Mark and Marcin
Did anyone open a TAC ticket or SR against this issue?
Mike
