Small Business Switch CBS350 IPV6 Configuration not appearing on GUI
ndallaris
Small Business Switch CBS350 IPV6 Configuration not appearing on GUI via the web interface.  When I login to the CBS350-12XT I need to configure IPV6 settings but the "IPV6 Configuration" Link is not appearing on the menu on the left side.  It was there and now it is not.   When I search for IPV6 settings it almost appears as if it is disabled.
Check if you are in the "Advanced Display Mode" or if you switched to Basic where many options are not shown.
ndallaris
Thanks, That was it.
