Stateless and Stateful DHCPv6 lab 8.2.3.5 question
Sagoito
I was doing https://www.configrouter.com/ccna-rse-lab-configuring-stateless-stateful-dhcpv6-11188/ this lab, after i finished it I changed prefix from 2001:db8:acad:a::/64 to 2001:db8:acad:b::/64 and after i did this I got 2 ip addresses on my PC one from SLAAC one from stateful dhcpv6. I am not sure why it happens. Can somebody explain it for me? Or how i can change it to work as i want to?
Harold Ritter
Level 12
Level 12
Pretty much all hosts do SLAAC by default. If you do not want this to happen, you need to specifically configure the router so it marks the router advertisement (RA) not to be used by the host to auto configure itself. The following configuration is required in IOS to accomplish that.
Do not advertise the prefix in the RA:
ipv6 nd prefix <prefix>::/64 no-advertise
or
Reset the A bit, which will cause the host not to use the prefix to auto configure itself:
no ipv6 nd prefix <prefix>::/64 infinite infinite no-autoconfig
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
