返信
Is it possible to set EtherChannel with ISR1111-8P?
Tnabe_Mio
I have some question. Please answer.
Routed port possible?
Is it possible with switchport?
Best regards
5件の返信5
if the router accept the command
and then you do
show etherchannel summary <<- and you see PO is RU then sure the router support L3 PO
Thank you for your answer.
Best regards
Hello.
Unfortunately, It's not possible neither.
Best regards
