返信
WS-C2960L-8PSLL パスワードリカバリ手順 switch: flash_initが実行できない
kei10omo
MODEボタン長押しにて電源起動を行い
「lash_init」コマンドを投入しましたが以下のような状態となりました。
手順に間違えがありますでしょうか?
 switch:
 switch: flash_init
 Unknown cmd: flash_init
*** 以下全ログ ***
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
Board H/W SKU Id is (1)
DDR3 Training Sequence - Ver TIP-1.27.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
DDR3 Training Sequence - Start scrubbing
DDR3 Training Sequence - End scrubbing
BootROM: Image checksum verification PASSED
Board SKU ID is (1)
FPU initialized to Run Fast Mode.
FPGA: 1.5
DRAM Size: 512 MB
Xmodem file system is available.
USB EHCI 1.00
Using driver version 1 for media type 3
yaffs[9]: Initialization complete.
yaffs[10]: Initialization complete.
yaffs[11]: Initialization complete.
Base ethernet MAC Address:
The password-recovery mechanism is enabled.
*** The system will autoboot in 5 seconds ***
Send break character to prevent autobooting.
The system has been interrupted. The following commands
will finish loading the operating system software:
boot
switch:
switch: flash_init
switch:
switch:
switch: load_helper
Unknown cmd: load_helper
switch:
switch: help
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
format -- Format a filesystem
help -- Present list of available commands
memcpy -- Copy from file to memory
memdump -- Dump memory
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
nand -- nand utility - check bad blocks
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
sleep -- Pause (sleep) for a specified number of seconds
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
-- MORE --
version -- Display boot loader version
switch:
switch: dir flash:
Directory of flash:/
258 -rwx 52 <date> express_setup.debug
514 drwx 2048 <date> c2960l-universalk9-mz.152-7.E2
503 drwx 2048 <date> dc_profile_dir
517 drwx 2048 <date> online_diag
770 -rwx 33 <date> pnp-tech-time
515 -rwx 66346 <date> pnp-tech-discovery-summary
516 -rwx 676 <date> vlan.dat
257 -rwx 1520 <date> config.text
1027 -rwx 1921 <date> private-config.text
772 -rwx 5144 <date> multiple-fs
2 drwx 2048 <date> lost+found
204246K bytes available (34730K bytes used)
switch:
switch:
1件の返信1
Akira Muranaka
Level 8
Level 8
ちょっと原因はわかりかねるのですが、とりあえず無いコマンドは飛ばして、以下URL参考に config.textの名前をかえてから Bootしてみてはいかがでしょうか。
http://brainsmash01.jugem.jp/?cid=8
