2012-10-04 06:39 PM
お世話になります。
WS-C3750V2/WS-C3560V2 および WS-C3750E/WS-C3560E は DoM コマンド(show interfaces transceiver detail)をサポートしていますでしょうか?
以下の機器では確認済みです。
WS-C3750-24PS @ 12.2(55)SE5 - 未サポート
WS-C3750X , WS-C2960S @ 15.0(2)SE - サポート
C3750X# show interfaces transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).Optical Optical
Temperature Voltage Tx Power Rx Power
Port (Celsius) (Volts) (dBm) (dBm)
Gi2/1/1 44.2 3.27 -5.2 -40.0C3750X# show interfaces transceiver detail
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Gi2/1/1 44.2 109.0 103.0 -13.0 -29.0High Alarm High Warn Low Warn Low Alarm
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Gi2/1/1 3.27 3.90 3.70 2.90 2.70Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Gi2/1/1 -5.2 -2.0 -2.0 -11.0 -13.0Optical High Alarm High Warn Low Warn Low Alarm
Receive Power Threshold Threshold Threshold Threshold
Gi2/1/1 -40.0 1.0 -1.0 -18.0 -20.0
C2960S# show interfaces transceiver
Gi2/0/25 33.7 3.26 -5.3 -40.0
C2960S# show interfaces transceiver detail
Gi2/0/25 33.7 90.0 85.0 -5.0 -10.0High Alarm High Warn Low Warn Low Alarm
Gi2/0/25 3.26 3.63 3.47 3.14 2.97Optical High Alarm High Warn Low Warn Low Alarm
Gi2/0/25 -5.3 0.0 -3.0 -9.5 -13.5Optical High Alarm High Warn Low Warn Low Alarm
Gi2/0/25 -40.0 3.0 0.0 -17.0 -21.0
C3750#show interfaces transceiver detail
C3750#show int gi 1/0/1 transceiver
Diagnostic Monitoring is not implemented.C3750#show int gi 1/0/1 transceiver properties
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: auto
Operational Duplex: auto
Operational Auto-MDIX: on
Media Type: 1000BaseSX SFP
2012-10-11 06:37 PM
こんにちは
バージョンとトランシーバの種類に依存しています。
以下のドキュメントを参照頂くとよいと思います。
宜しくお願い致します。
2012-10-12 11:36 AM
ご回答、ありがとうございます。
質問文に貼付した出力例ですが、GLC-SX-MM と SFP-GE-S の区別なく検証を実施しておりました。
再度、SFP-GE-S を用いて WS-C3750-24PS @ 12.2(46)SE にて確認したところ以下の出力を得ることができました。
Cat3750G#show interfaces transceiver detail
Transceiver monitoring is disabled for all interfaces.mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
Gi1/0/26 46.4 109.0 103.0 -13.0 -29.0High Alarm High Warn Low Warn Low Alarm
Gi1/0/26 3.33 3.90 3.70 2.90 2.70High Alarm High Warn Low Warn Low Alarm
Current Threshold Threshold Threshold Threshold
Port (milliamperes) (mA) (mA) (mA) (mA)
Gi1/0/26 5.0 15.0 12.0 2.0 1.0Optical High Alarm High Warn Low Warn Low Alarm
Gi1/0/26 -5.5 -2.0 -2.0 -11.0 -13.0Optical High Alarm High Warn Low Warn Low Alarm
Gi1/0/26 -26.2 -- 1.0 -1.0 -18.0 -20.0
Cat3750G#
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
下記より関連するコンテンツにアクセスできます
