10.5.2 Delete Softkey Error
Greenberet
Level 8
Level 8
I'm trying to delete a softkey via SQL.
delete from softkeyset
where pkid = '36b2c65e-f321-4bbe-851b-584ab2612efb';
Over the AXL I will just receive "Failure" as an error message.
The AXL Trace on the CUCM isn't really helping
2015-03-12 06:31:28,809 INFO  [http-bio-443-exec-21] servletRouters.AXLAlpha - AXL REQUEST :
2015-03-12 06:31:28,810 DEBUG [http-bio-443-exec-21] servletRouters.AXLAlpha - Request processed by AXIS
2015-03-12 06:31:28,814 DEBUG [http-bio-443-exec-21] axlapiservice.Handler - dbConnector Initialization in handler.java
2015-03-12 06:31:28,814 DEBUG [http-bio-443-exec-21] axlapiservice.Axl - Connection given to current thread
2015-03-12 06:31:28,815 DEBUG [http-bio-443-exec-21] axlapiservice.Axl - Thread is same so connection is reused, name of thread : http-bio-443-exec-21
2015-03-12 06:31:28,816 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - In begin transaction of AXLCallflow and created pub connector
2015-03-12 06:31:28,816 DEBUG [http-bio-443-exec-21] axlapiservice.AXLAPIServiceSkeleton - In ExecuteSQLQueryResponseDocument
2015-03-12 06:31:28,816 DEBUG [http-bio-443-exec-21] axlapiservice.ExecuteSqlHandler - delete from softkeyset
2015-03-12 06:31:28,887 WARN  [http-bio-443-exec-21] axlapiservice.ExecuteSqlHandler - java.sql.SQLException: -1
2015-03-12 06:31:28,888 ERROR [http-bio-443-exec-21] axlapiservice.AXLAPIServiceSkeleton - SQL EXCEPTION has occurred, will be sending you the exact error Info
2015-03-12 06:31:28,888 DEBUG [http-bio-443-exec-21] axlapiservice.Axl - Thread is same so connection is reused, name of thread : http-bio-443-exec-21
2015-03-12 06:31:28,892 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - In rollback transaction and created pub connector
2015-03-12 06:31:28,893 DEBUG [http-bio-443-exec-21] axlapiservice.Axl - Connection closed and hashmap entry removed in AXL.java closing connection
2015-03-12 06:31:28,893 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - Rollback transaction connector object closed
2015-03-12 06:31:28,894 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - In AXL CAll Flow class, method getSOAPError
2015-03-12 06:31:28,894 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - checking typeDBErrors for sql exception name
2015-03-12 06:31:28,903 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - Setting soap fault
2015-03-12 06:31:28,904 DEBUG [http-bio-443-exec-21] axlapiservice.AXLCallFlow - Setting soap fault2
2015-03-12 06:31:28,908 DEBUG [http-bio-443-exec-21] servletRouters.AXLAlpha - soapenv:ClientFailure-1FailureexecuteSQLUpdate2015-03-12 06:31:28,908 DEBUG [http-bio-443-exec-21] servletRouters.AXLAlpha - Finished processing request
2015-03-12 06:31:28,908 INFO  [http-bio-443-exec-21] filters.TimingFilter - Request 1426070393579 was processed in 132ms
Has anyone an Idea about this?
A couple of thoughts:
- Check that the pkid you are trying to delete is actually an existing row pkid in the softkeyset table (sure you've already done this)
- The Data Dictionary mentions this restriction when deleting rows from softkeyset:
Mandatory Softkeys cannot be removed from a Call State (except when a Service is removed
from the softkey template).
- Not sure if removing softkeys from the built-in templates is allowed (are you doing this?)
- Perhaps executing the SQL from the CUCM command line ('run sql delete from softkeyset where pkid="uuid"') might give a more helpful error message
dstaudt
Make sure you are using <executeSqlQuery> for read-only SQL requests, and <executeSqlUpdate> for any write requests (like this 'delete' operation)
Thx for the reply.
I checked it again and it IS an executeSqlUpdate.
Here is the complete SOAP Request:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
    <soap:Body>
        <executeSQLUpdate xmlns="http://www.cisco.com/AXL/API/10.5">
            <sql xmlns="">delete from softkeyset where pkid = '36b2c65e-f321-4bbe-851b-584ab2612efb'</sql>
        </executeSQLUpdate>
    </soap:Body>
</soap:Envelope>
the result on the command line was "-1"
That was the problem...
My first test was just a simple "Delete from softkeyset where fksoftkeytemplate = 'XXXXXXXXXX' and tkcallstate = 'X'"
this didn't work (with the error above) so I just grabbed a random guid and tried it also with it. And this guid was a mandatory field which leaded to my confusion because  I just wanted to delete a single entry.
I wanted to remove everything and then add the softkeys one by one with insert statements. But I guess I have to play with update/insert/and delete.
Thanks for your help 😃
