Add a ConferenceBridge to a MediaResourceGroup using AXL9
fabien.bonic
Level 5
Level 5
I have a MediaResourceGroup linked to a Conference Bridge. I want to link it to a second Conference Bridge. The request is :
<S:Envelope xmlns:S="http://schemas.xmlsoap.org/soap/envelope/">
<S:Body>
<ns2:updateMediaResourceGroup xmlns:ns2="http://www.cisco.com/AXL/API/9.0">
<name>MRG_FB2</name>
<description/>
<multicast>false</multicast>
<removeMembers/>
<addMembers><member><deviceName>CFB_3</deviceName></member></addMembers>
</ns2:updateMediaResourceGroup>
</S:Body>
</S:Envelope>
But the answer of the CUCM is : "At least one Media Resource is required for a Group. Please select a Media Resource to continue".
So how can I link a new Conference Bridge to this Media Resource Group ?
Fabien
amoherek
Hi Fabien,
Please delete <removeMembers/> from your request.
I originally thought this was a bug, but found out if you have null values for <removeMembers> and/or <members> then it will not work correctly. You will have to use only one of the three elements in your request: removeMembers, addMembers, or members.
Here is a working example:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.0">
<soapenv:Header/>
<soapenv:Body>
    <ns:updateMediaResourceGroup sequence="?">
        <name>Media Resource Group 1</name>
        <description/>
        <addMembers>
            <member>
                <deviceName uuid="43ebf083-0124-4635-8bfa-849e5903afb3">CFB_2</deviceName>
            </member>
        </addMembers>
    </ns:updateMediaResourceGroup>
</soapenv:Body>
</soapenv:Envelope>
Adrienne
amoherek
Hi Fabien,
<soapenv:Header/>
<soapenv:Body>
        <description/>
        <addMembers>
            <member>
            </member>
        </addMembers>
</soapenv:Body>
</soapenv:Envelope>
Adrienne
Hi Adrienne,
Thank you for this answer. You are right, deleting "removeMember from the request made a correct result.
Fabien
