Add phone with an existed line
jialinli
I tried to add a new device to CUCM and add an existed line to this phone at the same time. When I use the uuid of the dirn, the phone can be added successfully, but when I tried to use the pattern and routePartitionName, it failed, the content in my xml file is:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:addPhone sequence="?">
         <phone ctiid="?">
            <name>SEPC47295A8D5B6</name>
            <description>Jia Ling Li (jialinli) - RedBaron PP - test</description>
            <product>Cisco 7811</product>
            <class>Phone</class>
            <protocol>SIP</protocol>
            <protocolSide>User</protocolSide>
            <devicePoolName uuid="?">Default</devicePoolName>
            <lines>
               <line ctiid="?">
                  <index>1</index>
                  <label>Jia Ling - 32011</label>
                  <display>Jia Ling Li</display>
                  <dirn uuid="?">
                     <pattern>32011</pattern>
                     <routePartitionName uuid="?">Global Learned E164 Patterns</routePartitionName>
                  </dirn>
                  <ringSetting>Ring</ringSetting>
                  <consecutiveRingSetting>Use System Default</consecutiveRingSetting>
                  <mwlPolicy>Use System Policy</mwlPolicy>
               </line>
            </lines>
            <phoneTemplateName uuid="?">Standard 7811 SIP</phoneTemplateName>
            <softkeyTemplateName uuid="?">Standard User</softkeyTemplateName>
            <enableExtensionMobility>false</enableExtensionMobility>
            <sshUserid>debug</sshUserid>
            <sshPwd>debug</sshPwd>
         </phone>
      </ns:addPhone>
   </soapenv:Body>
</soapenv:Envelope>
And the error I got is:
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server</faultcode><faultstring>Item not valid: The specified numPlanId was not found</faultstring><detail><axlError><axlcode>5007</axlcode><axlmessage>Item not valid: The specified numPlanId was not found</axlmessage><request>addPhone</request></axlError></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope>
Does this mean I could only use the uuid of the dirn to add line to the device?
jialinli
use <dirn ctiid="?"></dirn> will resolve the problem
jialinli
I want to add a phone with a given dir number to CUCM, without trying to get the uuid of the dirn, is this possible?
Or how can I get the uuid of dirn according to a phone number like "32011"?  I'm using CUCM 11.5.
jialinli
