addPhone- not all values take
stephan.steiner
My unit testing discovered that I'm having discrepancies between the values I'm sending in my addPhone and subsequent response to getPhone. The following 4 tags are affected
  1. consecutiveRingSetting (on line)
  2. joinAcrossLines
  3. singleButtonBarge
  4. missedCallLogging (on line)
I'd argue that if an add is accepted, the values I'm sending are correct, so they should be applied accordingly. Here's my full addPhone, followed by the result for getPhone
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
  <soapenv:Header/>
  <soapenv:Body>
  <ns:addPhone sequence="10">
  <phone>
  <name>UPCTEST</name>
  <description>Added phone SGRO</description>
  <product>Cisco Unified Client Services Framework</product>
  <class>Phone</class>
  <protocol>SIP</protocol>
  <protocolSide>User</protocolSide>
  <vendorConfig>
  <videoCapability>0</videoCapability>
  <desktopClient>
  <ciscoSupportField>configurationfile=jabber-config201_72.xml</ciscoSupportField>
  </desktopClient>
  </vendorConfig>
  <preemption>Disabled</preemption>
  <lines>
  <line>
  <index>1</index>
  <display>displöi</display>
  <dirn>
  <pattern>7306</pattern>
  <routePartitionName>p_phones</routePartitionName>
  </dirn>
  <ringSetting>Ring</ringSetting>
  <consecutiveRingSetting>Flash Only</consecutiveRingSetting>
  <e164Mask>044815XXXX</e164Mask>
  <mwlPolicy>Use System Policy</mwlPolicy>
  <maxNumCalls>2</maxNumCalls>
  <busyTrigger>1</busyTrigger>
  <callInfoDisplay>
  <callerName>true</callerName>
  <callerNumber>false</callerNumber>
  <redirectedNumber>false</redirectedNumber>
  <dialedNumber>true</dialedNumber>
  </callInfoDisplay>
  <recordingFlag>Call Recording Disabled</recordingFlag>
  <audibleMwi>Default</audibleMwi>
  <speedDial/>
  <partitionUsage>General</partitionUsage>
  <associatedEndusers>
  <enduser>
  <userId>testuser</userId>
  </enduser>
  </associatedEndusers>
  <missedCallLogging>false</missedCallLogging>
  <recordingMediaSource>Gateway Preferred</recordingMediaSource>
  </line>
  </lines>
  <phoneTemplateName uuid="{8E1A10FA-A52C-4435-A4EC-540D266C8C37}">Standard Client Services Framework</phoneTemplateName>
  <singleButtonBarge>Off</singleButtonBarge>
  <joinAcrossLines>On</joinAcrossLines>
  <callInfoPrivacyStatus>Default</callInfoPrivacyStatus>
  <ignorePresentationIndicators>false</ignorePresentationIndicators>
  <dndOption>Ringer Off</dndOption>
  <dndRingSetting>Beep Only</dndRingSetting>
  <dndStatus>true</dndStatus>
  <alwaysUsePrimeLine>Default</alwaysUsePrimeLine>
  <alwaysUsePrimeLineForVoiceMessage>Default</alwaysUsePrimeLineForVoiceMessage>
  <callingSearchSpaceName uuid="{BC3B6B1C-ADF4-2B1D-F723-4A927AAFFE89}">CSS_UNRESTRICTED</callingSearchSpaceName>
  <devicePoolName uuid="{1B1B9EB6-7803-11D3-BDF0-00108302EAD1}">Default</devicePoolName>
  <commonPhoneConfigName uuid="{AC243D17-98B4-4118-8FEB-5FF2E1B781AC}">Standard Common Phone Profile</commonPhoneConfigName>
  <networkLocation>Use System Default</networkLocation>
  <locationName uuid="{29C5C1C4-8871-4D1E-8394-0B9181E8C54D}">Hub_None</locationName>
  <useTrustedRelayPoint>Default</useTrustedRelayPoint>
  <retryVideoCallAsAudio>true</retryVideoCallAsAudio>
  <securityProfileName uuid="{C6085E14-A32C-4C5E-A3D1-8DAF60D81594}">Cisco Unified Client Services Framework - Standard SIP Non-Secure Profile</securityProfileName>
  <sipProfileName uuid="{FCBC7581-4D8D-48F3-917E-00B09FB39213}">Standard SIP Profile</sipProfileName>
  <useDevicePoolCgpnTransformationCss>true</useDevicePoolCgpnTransformationCss>
  <sendGeoLocation>false</sendGeoLocation>
  <ringSettingIdleBlfAudibleAlert>Default</ringSettingIdleBlfAudibleAlert>
  <ringSettingBusyBlfAudibleAlert>Default</ringSettingBusyBlfAudibleAlert>
  <enableExtensionMobility>false</enableExtensionMobility>
  <builtInBridgeStatus>Default</builtInBridgeStatus>
  <hlogStatus>On</hlogStatus>
  <ownerUserName>lsste</ownerUserName>
  <packetCaptureMode>None</packetCaptureMode>
  <packetCaptureDuration>0</packetCaptureDuration>
  <hotlineDevice>false</hotlineDevice>
  <allowCtiControlFlag>true</allowCtiControlFlag>
  <presenceGroupName>Standard Presence group</presenceGroupName>
  <unattendedPort>false</unattendedPort>
  <requireDtmfReception>false</requireDtmfReception>
  <rfc2833Disabled>false</rfc2833Disabled>
  <certificateOperation>No Pending Operation</certificateOperation>
  <deviceMobilityMode>Default</deviceMobilityMode>
  <remoteDevice>false</remoteDevice>
  <isActive>true</isActive>
  <isDualMode>false</isDualMode>
  <phoneSuite>Default</phoneSuite>
  <phoneServiceDisplay>Default</phoneServiceDisplay>
  <isProtected>false</isProtected>
  <mtpRequired>false</mtpRequired>
  <mtpPreferedCodec>711ulaw</mtpPreferedCodec>
  <outboundCallRollover>No Rollover</outboundCallRollover>
  <deviceTrustMode>Not Trusted</deviceTrustMode>
  <requireOffPremiseLocation>false</requireOffPremiseLocation>
  <useDevicePoolCgpnIngressDN>true</useDevicePoolCgpnIngressDN>
  <enableCallRoutingToRdWhenNoneIsActive>false</enableCallRoutingToRdWhenNoneIsActive>
  </phone>
  </ns:addPhone>
  </soapenv:Body>
</soapenv:Envelope>
<?xml version='1.0' encoding='UTF-8'?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
  <soapenv:Body>
  <ns:getPhoneResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
  <return>
  <phone ctiid="65" uuid="{885353D7-80A1-9AB0-F1C7-DCA84532A3D3}">
  <model>Cisco Unified Client Services Framework</model>
  <commonDeviceConfigName/>
  <mediaResourceListName/>
  <networkHoldMohAudioSourceId />
  <userHoldMohAudioSourceId />
  <automatedAlternateRoutingCssName/>
  <aarNeighborhoodName/>
  <loadInformation special="false"/>
  <vendorConfig>
  <desktopClient>
  </desktopClient>
  </vendorConfig>
  <versionStamp>{1422453380-4321482F-DF30-4F56-873A-D78CFD08BBD6}</versionStamp>
  <traceFlag>false</traceFlag>
  <mlppDomainId />
  <mlppIndicationStatus>Off</mlppIndicationStatus>
  <cgpnTransformationCssName/>
  <useDevicePoolCgpnTransformCss>true</useDevicePoolCgpnTransformCss>
  <geoLocationName/>
  <geoLocationFilterName/>
  <lines>
  <line uuid="{72C150A1-330A-E096-4856-CE17549F94C3}">
  <index>1</index>
  <label/>
  <dirn uuid="{8C38931B-B59A-66ED-27A2-A48D97243C69}">
  <routePartitionName uuid="{82056F6A-7CF2-48DA-BDEB-9E17B12DE19D}">p_phones</routePartitionName>
  </dirn>
  <consecutiveRingSetting>Use System Default</consecutiveRingSetting>
  <ringSettingIdlePickupAlert />
  <ringSettingActivePickupAlert />
  <displayAscii/>
  <dialPlanWizardId />
  <callInfoDisplay>
  </callInfoDisplay>
  <recordingProfileName/>
  <monitoringCssName/>
  <speedDial />
  <enduser>
  </enduser>
  <missedCallLogging>true</missedCallLogging>
  </line>
  </lines>
  <numberOfButtons>1</numberOfButtons>
  <speeddials/>
  <busyLampFields/>
  <primaryPhoneName/>
  <blfDirectedCallParks/>
  <addOnModules/>
  <userLocale />
  <networkLocale />
  <idleTimeout />
  <authenticationUrl />
  <directoryUrl />
  <idleUrl />
  <informationUrl />
  <messagesUrl />
  <proxyServerUrl />
  <servicesUrl />
  <services/>
  <softkeyTemplateName/>
  <loginUserId />
  <defaultProfileName/>
  <currentProfileName/>
  <loginTime />
  <loginDuration />
  <currentConfig>
  <mlppDomainId />
  <singleButtonBarge>Default</singleButtonBarge>
  <joinAcrossLines>Off</joinAcrossLines>
  <dndStatus />
  <emccCallingSearchSpaceName xsi:nil="true" uuid="" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"/>
  <deviceName/>
  <model/>
  <product/>
  <deviceProtocol/>
  <class/>
  <addressMode/>
  <allowAutoConfig/>
  <remoteSrstOption/>
  <remoteSrstIp/>
  <remoteSrstPort/>
  <remoteSipSrstIp/>
  <remoteSipSrstPort/>
  <geolocationInfo/>
  <remoteLocationName/>
  </currentConfig>
  <ownerUserName uuid="e8854125-510c-d08f-79fd-7fc0b78b3c85">lsste</ownerUserName>
  <subscribeCallingSearchSpaceName/>
  <rerouteCallingSearchSpaceName/>
  <presenceGroupName uuid="{AD243D17-98B4-4118-8FEB-5FF2E1B781AC}">Standard Presence group</presenceGroupName>
  <certificateStatus>None</certificateStatus>
  <upgradeFinishTime />
  <mobilityUserIdName/>
  <dialRulesName/>
  <sshUserId/>
  <digestUser/>
  <secureInformationUrl />
  <secureDirectoryUrl />
  <secureMessageUrl />
  <secureServicesUrl />
  <secureAuthenticationUrl />
  <secureIdleUrl />
  <featureControlPolicy/>
  <confidentialAccess>
  <confidentialAccessMode />
  <confidentialAccessLevel>-1</confidentialAccessLevel>
  </confidentialAccess>
  <cgpnIngressDN/>
  <msisdn />
  <wifiHotspotProfile/>
  <wirelessLanProfileGroup/>
  </phone>
  </return>
  </ns:getPhoneResponse>
  </soapenv:Body>
</soapenv:Envelope>
jocreed
Hmmm... I will try to reproduce this one in my lab and get back with you to see if I am getting similar results.
